1- After engine start the starter engaged warning light remains lit. The correct action would be :
a) continue with the after start check as this is normal.
b) wait 60 seconds and shut down if the light is still on.
c) shut down immediately.
d) shut down within 30 seconds.
2- An ignition switch which is shorted out at one magneto would result in :
a) the generator being tripped off line.
b) inabilitu of the engine to start.
c) inability of the engine to stop.
d) a dead cut when the other magneto is switched off.
3- "Superfine" pitch on a turbine powered aircraft :
a) provides more power at high altitude.
b) aids in windmilling and relighting the engine.
c) provides more power at low altitude.
d) require less power for starting.
I'd say answer D.
Thank you.
