ecam warning long range
white-eagle
Message par white-eagle »
bonjour la liste,
je désire connaître la différence entre ces 2 ECAM Warnings :
hyd G rsvr underfilled et hyd G rsvr low lo lvl
merci de vos retours ☺
W-E
5AM1
Message par 5AM1 »
HYD G RSVR LO LVL :
Triggering Conditions:
This alert triggers when the fluid quantity < 8 l (2.11 US Gal).
HYD G RSVR UNDERFILLED (ON GROUND)
This alert triggers on ground:
&#8208; If the reservoir quantity is below 17 l when the temperature is above 0 °C, or
&#8208; If the reservoir quantity is below a quantity function of the temperature when the temperature is below 0 °C.
